01-22-2015 04:50 AM
I'm using Engine Demo project with VeriStand 2014. I want to execute it in cRIO-9033, so I've included in the system definition file an RT Controller selecting VxWorks for the OS, and using the same IP address displayed for the CompactRIO system in MAX. When I deploy the System Definition File, VeriStand Gateway encountered an error. The ethernet cable is connected and it's running because it's answering to a ping command.
I've read I need to install NI VeriStand Engine on the real-time target (cRIO-9033) but when I select Custom Software Installation from MAX in Remote Systems->cRIO9033->Software->Add/Remove Software, NI VeriStand Engine is not inside possible features to install. Could be this the problem?How can be resolved?
Thank you in advance
01-23-2015 10:45 PM
