02-24-2016 12:25 AM
1)I tried to deploy the example of sinewave delay to PXI 8115 RT system,but the deployment failed with this error message,What causes the error, and how can I solve the problem?
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error 1003 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
LabVIEW: 无法执行该VI。造成该错误的原因可能是VI断开或者子VI无法定位。选择文件>>打开可打开VI并确保可以运行该VI。
NI VeriStand: Launch Asynchronous VI by Name.vi->Model Execution.lvlib:Launch Model Loops.vi->NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi->NI VeriStand Engine.lvlib:VeriStand Engine.vi->NI VeriStand Engine.lvlib:VeriStand Engine Wrapper (RT).vi中的打开VI引用<APPEND>
Model Execution.lvlib:Model Execution Loop.vi
2)I have a error when searching for devices on my PXI-8115, NI System Configuration 14.0 is installed on the target.
