VeriStand
Mapping (so close ...)
I'm so close to do programatically the mapping but I have at least a problem : I don't know the syntax that LabVIEW/Veristand need ...
As you can see, i try to map 2 channels but the indicator AddChannelMapping2 never turns to green, that's mean the mapping doesn't work ...
I think the problem comme from the way that I wrote my cahnnel path, but I have no idea what Labview needs to map my 2 channels
Any idea ? Thanks !
Message 1 of 14
(5,103 Views)
Maybe you're trying to map 2 inputs together ?
Message 2 of 14
(5,100 Views)
Hello Thumble and thanks for your answer (again !)
The 2 Inputs come from a Custom Device. I've tried to map them with Veristand and it was a success.
Do you know what kind of syntax does Labview needs to do the map ?
Message 3 of 14
(5,096 Views)
Re,
I've never used that from LabVIEW, but your syntax don't shock me expect that you're mapping .../Inputs/LambdaAval to .../Inputs/LambdaAmont, as I would expect somthing like .../Outputs/LambdaAmont to .../Inputs/LambdaAval
Message 4 of 14
(5,089 Views)
Yes Thumble, I completely admit that is a weird example, but as you can see on the picture below, this is not an error cause I can do it in Veristand :
I have the same problem with other channel for map. I don't what to do now ...
Message 5 of 14
(5,087 Views)
Re,
Ok I see, I think it's your channel name that is bad, try using the string "Controller/.../Inputs/Lambda Aval" with or without a leading "/".
Message 6 of 14
(5,084 Views)
Yes I think so,
I've tried some channel name like:
"Controller/Custom Devices/Sonde_O2/Inputs/Lambda Aval" or
Controller/Custom Devices/Sonde_O2/Inputs/Lambda Aval or
Controller/Custom Devices/Sonde_O2/Inputs/Lambda Aval/
But no success ...
Message 7 of 14
(5,082 Views)
Try to export your mappings (from Veristand) to a text file and use the same syntax as in this file.
Message 8 of 14
(5,077 Views)
That was the 1st thing I've done ... No more success too ...
This is gonna kill me ...
Message 9 of 14
(5,075 Views)
Sorry but I have no more idea. I guess you must be doomed to fall into that kind of tricky case. Perhaps someone from the Veristand team can help ?
Just to check an eventual point: when I export an exemple I got names like "Targets/Controller/Custom Devices/LheTest/Channels/A/vl0/ENABLE_TAG" (begining with Targets/...) as I saw your path starting with "Controller/..." can't it be just that ?
Good luck.
Message 10 of 14
(5,072 Views)
