VeriStand
Linux RT
I just had a look at VeriStand 2014 and it seems that Linux RT targets are not supported yet :
Linux RT - Veristand
I was just wondering what is the roadmap for supporting Linux RT targets in VeriStand ?
When will we be able to use Linux RT CompactRIOs like cRIO-906x in VeriStand (I mean natively) ?
Da Helmut
Voir le profil de Maxime M. sur LinkedIn - View Maxime M.'s profile on LinkedIn
(6,422 Views)
You are correct that VeriStand 2014 does not currently support Compact RIO targets running the LinuxRT operating system. We are currently evaluating our roadmap for this support and would welcome any feedback you might have. Is there a particular application you are working on that is well-suited to one of these cRIOs?
Note that there is a product, the NI LabVIEW Model Interface Toolkit, that does support running models built for the VeriStand Model Framework on the Arm32-based LinuxRT targets, such as the cRIO-9068. This toolkit is a little different than VeriStand. It is a LabVIEW toolkit for programming real-time applications that make use of models.
Jarrod S.
(6,417 Views)
are there any new informations concerning NI Linux RT Support for Veristand?
Arnold
(5,621 Views)
I would also be interested in Linux RT Support.
Remember Cunningham's Law
(5,473 Views)
If you want to see the latest features in VeriStand you should sign up for the  NI VeriStand 2015 Beta program. I suspect you would find it very interesting.
-K_Scott
(5,361 Views)
