07-21-2016 04:47 AM
Helo,
I'm usign Ni veristand 2014 and with the stimulus profile editor I need to iteratively play N times the same csv file.
In the stimulus profile editor I can load correctly a csv file into a Real-Time sequence, but i can't see how to iterate the sequence N times in the stimulus profile.
Is there a way to accomplish that?
Thanks in advance to everyone!
Davide
07-25-2016 12:19 PM
Hey Davide,
You can actually add a For Loop step in the Real-Time sequence itself. If you pass the number of iterations, N, as a parameter to the RT sequence, you will be able to set it from your stimulus profile.
If you are looking to get a pass/fail for each iteration of the test, there's not a great way to do that natively with the VeriStand Stimulus Profile Editor. The alternatives are to use TestStand with the VeriStand Custom Step Types or programmatically generate a stimulus profile that calls the RT Sequence N times back to back using the VeriStand Stimulus Profile Definition API.
07-25-2016 02:44 PM
Than's for your answer Cody.
From what I can see the real time sequence can be or just a csv file or a sequence in wich you can actually use programming steps.
I don't see how to mix steps with csv file replay.
Am I doing something wrong?
If it's not possible doing the iteration with the native stimulus I will use the API.
Thank you
Davide
07-25-2016 03:19 PM
Apologies - I missed the csv file part of your original post.
You are correct, an RT Sequence call from a stimulus profile can target either an RT sequence file or a csv file. Since you are using a CSV file, there is no native way to iteratively replay that CSV file. My recommendation would be to use the API. You should be able to find a couple examples of programmatically creating profiles and RT sequences by searching around.
07-25-2016 04:16 PM
Hello Cody,
thanks for your help.
Then I'll look for APIs so!
Thanks for the english lesson too 😉
Davide
12-16-2016 06:07 PM
I've found this link to create a sequence from a csv!
From this sequence is possible to use the sequence also in a for loop or other structures.
http://forums.ni.com/t5/Community-Documents/CSV-to-NIVSSeq-vi/ta-p/3524575
I hope it can be useful for someone!
Davide
