03-18-2016 12:20 PM
I implemented a custom workspace object using the tutorial found here:
http://www.ni.com/tutorial/9989/en/
I used the configuration VI and add channel VI from the zip file there for my own stuff. I did not change the add channel VI in anyway, simply included it in my project. When adding the custom workspace object to the VeriSTAND workspace, the configuration VI launches. There is a select button for choosing a channel. Pressing this button lauches the add channel VI. It appears that the VI "hangs" and the channels do not populate in the list screen. I know that the channels are there because one can add a regular VS numeric control and right-click, the channels are there.
What could cause the add channel VI to hang?
Solved! Go to Solution.
03-18-2016 12:23 PM
Sorry,
This is for a custom workspace object and the custom device itself...
03-18-2016 01:27 PM
This is the VI that runs for our custom workspace object when the user wants to add a channel. Comes directly from the tutorial.
03-18-2016 03:14 PM
Found implementation that works here:
