04-21-2014 07:25 AM
I am wondering the purpose of parameters & signals vs. inports?
Are parameters only to be used for initialization with the 'Model initial values' custom device?
I figured that I would have been able to initialize them via TestStand, but they don't appear in TestStand.
I currently am using labview models and don't see how to add signals to the model in labview.
04-21-2014 07:28 AM
Actually, I don't see how to update the parameters via the 'Model initial values' custom device either.
Parameters don't seem to show up anywhere except under the model in the system explorer.
04-29-2014 12:46 PM - edited 04-29-2014 12:54 PM
Hi daufdi13,
Since you are using the Model Initial Values Custom Device, there is a dedicated forum for support for that particular NI VeriStand Add-on here: https://decibel.ni.com/content/thread/8437?tstart=0
In this thread, you will find a post by Dustin_DD on Jul 21, 2010 who had a similar question to the one you posted here where the developer offered a response. Hope this helps!
Sincerely,
05-26-2015 07:28 PM
I received "The item does not exist. It may have been deleted." after clicking the link.
05-27-2015 08:54 AM
All of our unsupported IP has been transitioned to GitHub. You can download the source for the Model Initial Values custom device and build it for your own use.
