VeriStand
I needs to display, on a mimic, the CPU load of the real time controller under Veristand.
But a didn't find a system channel (or equivalent) with this data.
I have a controller with 8 CPU cores (RMC8355) , so I need to have the 8 CPU loads.
Someone have a solution ?
Thank
(5,736 Views)
If you install the "System State Publisher" on your RT Target, the target will publish the CPU loads for each core.
You can gather all these informations reading the published shared variables either by opening the "distributed system manager" NI tool or using labview code:
example for the eighth core of the target wich IP is 191.230.14.156
ni.var.psp://191.230.14.156/NI_SystemState/CPULoad/CPU7/Total
You could moreover put that code into a custom device and link CPU Load values to output channels.
(5,731 Views)
Accepted by topic author FFC
The System Monitor custom device available on the add-ons page will allow you to get this information and more as channels in your system definition.
Jarrod S.
(5,724 Views)
thanx!
I didn't know this VCD was existing!
I'll fall asleep less idiot tonight!
(5,717 Views)
