04-07-2014 10:50 AM
I get back to a subject that was already discussed but with no solution.
We've built a big VeriStand project (based on 2011SP1) that has now been deployed to several worldwide locations. Since we use the 2011 version, we had to use the "scaling & calibration" function to scale bus data.
Today a new bus specification requires making changes on some scales. To avoid running around the world I would like my customers to send me their “HardwareCalibrationData.nivscal” files in order to patch and send them back.
I don’t want to use a running VeriStand project to do that because the customer’s configurations are slightly different with only a set of channels being concerned by the scale update (the others may hold scales and/or calibration factors that must not be disturbed).
So I’ve imagined developing a tool for doing the patch but I can’t because I have neither file format specification nor S/W module or code extract.
Note: I don’t care about the history file, only about the HardwareCalibrationData.nivscal.
Any help would be appreciated, best regards
Solved! Go to Solution.
04-07-2014 01:36 PM
These APIs should do what you want. Note that I believe they will ONLY work up through NI VeriStand 2011 SP1. However, that sounds like what you want.
04-08-2014 01:28 AM
Thank you Jarrod, that's exactly what we need.
08-04-2023 02:25 AM
Hi Jarod
Any update of this exemple for VeriStand 2020 ?
08-04-2023 04:43 AM
Hi kabooom,
Here is an updated solution for reading nivscal files (for at least VeriStand 2020):
The data is prepended with the version number in plain ASCII, then the rest of the data is a cluster flattened in binary. Excepted for the first 4 bytes (always equal to 0x00 ?), I could decode all the calibration data. See the project attached.
Raphaël.
