Should I write to VeriStand Channels as needed or "on-update" or should I try to reduce the number of calls to the VS gateway and write them at once?
I have a design choice to make with a new project about how/when I should update the VeriStand system definition channel values from my software. In previous projects, the design choice was made to try to consolidate all value updates and write to VeriStand once with all the channels' name-value pairs. This required some effort to structure and seems a little unnecessary. I would prefer to write to VS wherever I need to. Is there any serious concern with this.
Note, IF I need the updates to be serial for some reason I would have those dependent channels updated at the same time. In almost all cases, I do not care what order they are updated.
