01-12-2016 09:15 AM
I have installed Matlab 2014a, Visual Studio2012 and Eclipse 2014 in my computer. The operating system is windows 7. And the veristand frame work model is succesfully deployed to matlab-simulink as shown in the command window in Matlab.
But when I'm trying to build a .so file for my cRIO through"Simulation---->Model Configuration Parameters--->build", while using "NIVeristand_Linux_64.tlc" as system target file. The complition is successful but during the building process, here comes the error as shown below,which said that my Eclipse was not installed properly. And it's very strange that even I unistalled the Eclipse 2014, the error is the same. Is there anything wrong when I installed Eclipse 2014, or is there some special configuration after installing Eclipse 2014?
Thank you for your attention and helping!
01-13-2016 04:14 PM
Hello weily411
01-14-2016 02:45 AM
Thank you for your attention and help!
The version of Veristand is "2015.0.0.117 (2015)" as shown in matlab.
And I download the Eclipse exactly from the website you offered.Actually I followed the guides from the link"http://digital.ni.com/public.nsf/allkb/E552B0CD4E48215586257DF7005BE055" to use veristand ,eclipse and matlab-simulink to build the .so file for cRIO.
Is the question have something to do with the softwares in my computer such as Visual Studio 2012? Or are some certain C++ compilers are necessary for Eclispe? I've also installed Java SDK and Java SE on my computer as guided by the link you offered, but it doesn't work....
Best Regards~
01-14-2016 02:47 PM
I do not suspect MSVS 2012 to be the cause of the issue.
Does this folder exist on your system?
Remove and reinstall Eclipse
Following procedures will further help me to understand where the detection is failing:
01-14-2016 08:42 PM
Thanks a lot Nestor!
I didn't installed the Eclipse in the default path, and I've change it to" E:\National Instruments\Eclipse\14.0". Actually I have installed all the concerned NI softwares in thepath " E:\National Instruments", including Veristand. Must these softwares be installed to the default path in the system disk? Or must the softwares have to be installed in a files called " Program Files" or "Program FIles(X86)" when installed to other disks?
And it was indeed not installed with a Administrator Privalige. Is that privilage necessary during the installation?
The folder you mentioned does exist in "E:\National Instruments\Eclipse\14.0\x64\sysroots\i686-nilrtsdk-mingw32\usr\bin\x86_64-nilrt-linux" with 25 ".exe" files in it.
I run the ".bat" files through cmd seperately in disks C:\ and E:\ and the results seem the same. And the "not properly installed" error is reported at the end of the ".log" as below.
Best Regards~
C:\>REM This file configures several environment variables, including PATH, for C:\>REM use with the gcc compiler redistributable. Execute this within a Command C:\>REM Shell to configure it for development. Alternatively, integrate these C:\>REM environment variable settings into your computer settings. C:\>REM Build path to C & C++ Development Tools for NI Linux Real-Time, Eclipse Edition C:\>set NIGCC_VERSION=14.0 C:\>set ECLIPSE_VERSION_LABEL=2014 C:\>echo Setting environment for using NI Linux Real-Time 2014 64-bit tools. Setting environment for using NI Linux Real-Time 2014 64-bit tools. C:\>REM If 64-bit OS, find registry key to National Instruments root directory under WoW6432Node. C:\>set key="HKLM\Software\WOW6432Node\National Instruments\gccToolchain\14.0" C:\>REM If key not found, try under 32bit nodes C:\>reg query "HKLM\Software\WOW6432Node\National Instruments\gccToolchain\14.0" 2>NUL 1>NUL C:\>if ERRORLEVEL 1 (set key="HKLM\Software\National Instruments\gccToolchain\14.0" ) C:\>REM Check existence of key C:\>reg query "HKLM\Software\National Instruments\gccToolchain\14.0" 2>NUL 1>NUL C:\>IF ERRORLEVEL 1 GOTO ERROR C:\>echo Error locating the NI Linux Real-Time 2014 toolchain. Confirm the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition 2014 was properly installed. Error locating the NI Linux Real-Time 2014 toolchain. Confirm the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition 2014 was properly installed. C:\>EXIT /B 1
E:\>REM This file configures several environment variables, including PATH, for E:\>REM use with the gcc compiler redistributable. Execute this within a Command E:\>REM Shell to configure it for development. Alternatively, integrate these E:\>REM environment variable settings into your computer settings. E:\>REM Build path to C & C++ Development Tools for NI Linux Real-Time, Eclipse Edition E:\>set NIGCC_VERSION=14.0 E:\>set ECLIPSE_VERSION_LABEL=2014 E:\>echo Setting environment for using NI Linux Real-Time 2014 64-bit tools. Setting environment for using NI Linux Real-Time 2014 64-bit tools. E:\>REM If 64-bit OS, find registry key to National Instruments root directory under WoW6432Node. E:\>set key="HKLM\Software\WOW6432Node\National Instruments\gccToolchain\14.0" E:\>REM If key not found, try under 32bit nodes E:\>reg query "HKLM\Software\WOW6432Node\National Instruments\gccToolchain\14.0" 2>NUL 1>NUL E:\>if ERRORLEVEL 1 (set key="HKLM\Software\National Instruments\gccToolchain\14.0" ) E:\>REM Check existence of key E:\>reg query "HKLM\Software\National Instruments\gccToolchain\14.0" 2>NUL 1>NUL E:\>IF ERRORLEVEL 1 GOTO ERROR E:\>echo Error locating the NI Linux Real-Time 2014 toolchain. Confirm the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition 2014 was properly installed. Error locating the NI Linux Real-Time 2014 toolchain. Confirm the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition 2014 was properly installed. E:\>EXIT /B 1
01-15-2016 06:58 PM - edited 01-15-2016 07:01 PM
(Following the above message)
Uh, and I have reinstalled Eclipse with the Administrator Privalige to the same path above, but it didn't work... And the debugging result is the same.
At the same time, a correction to the previous description. My computer is not installed with Java SE and Java JDK. Is that the problem?
Thanks a lot!
01-18-2016 01:11 PM
Thank you weily411 for the cooperation and efforts.
It appears that the necessary files are indeed installed, but the registry isn't providing what we need.
The following request examines the registry for items we use to locate the install path.
01-19-2016 10:16 PM - edited 01-19-2016 10:18 PM
I have run the cmd with Admin Previlage and run the test file again, but the result is the still the same.
My window 7 is 64-bits. The following is the content in the certain locatioin of the registry, and it seems the same as what you have provided above, including the x64Path.
Weily
01-25-2016 12:42 PM
Hi weily411,
UnfortunatelyI was unable to reproduce the issue. What OS edition are you using?
01-30-2016 01:57 AM
My OS is 64-bit windows 7, English version with a Chinese pack. And the settings seems to be common here.
The problem has been solved by using other computer, so it should only be related to certain settings of my own computer.
Thank you all the same for the helping and assisting for this time.
Weily
