04-13-2016 12:54 PM
The sysdef I'm using is set to start at boot, but when the target is restarted it always throws error -89126 and I have to manually redeploy. Can this be fixed?
The sysdef I'm using is posted here: http://forums.ni.com/t5/NI-VeriStand/Why-is-DAQ-200714-error-fatal/td-p/3276882
Hardware is PXI-8110 in a PXI-1045 chassis
VeriStand 2015
Solved! Go to Solution.
04-14-2016 03:40 PM
Hey Stephen,
Some initial questions for you. While I dig into this specific error regarding the trig lines.
1. Are you able to use anything else for a timing source besides the DAQ card?
2. What cards do you currently have filling your chassis?
Rob S
04-14-2016 03:41 PM
04-14-2016 04:34 PM
04-15-2016 08:52 AM
Does the problem happen the first time a system definition starts up after reboot, or just if a system definition is set to start immediately after reboot? If you have no system definition deployed (you specifically undeploy the last one), and you reboot, and then wait a couple minutes before deploying one, do you still see the same issue?
If it happens to be a timing thing, we have an INI token you can use to delay the start-up of the VeriStand engine by some amount.
04-15-2016 12:34 PM
You da man Jarrod! That worked.
I had set it to 4000 ms already to avoid an 'unknown device' error, bumping it all the way to 16000ms avoided this error as well.
