VeriStand
Error 61060 Veristand
Hy to you all. I'm trying to deploy my Veristand project on cRio 9082 but I've always the same error: "Error 61060 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi"
I've see it can be related to the DMA write size, and I'm not sure if I'm doing correctly. I've attacched a picture about my vi.
Thanks in advance!
(6,643 Views)
Accepted by topic author Domenico_fed
I got it by my self... The error wasn't there...
(6,614 Views)
can u tell me ,thanks a lot
(5,782 Views)
The problem was in the XML file, where you write the number of DMA that you're going to read and write. Hope this can help
(5,772 Views)
The same error can arise when the bitfile referenced in the xml template is not your expected one.
Regards
(5,219 Views)
