10-05-2016 08:28 AM
Hi, during the project deployment onto RT Controller, I am getting error code -307743: "NI VeriStand: The VeriStand Engine failed to start. A configured start trigger or external timing source did not occur within the specified timeout". One of the timing source did not start. Using the NI VeriStand 2013 f2 Patch did not help. Increasing the timeout also did not help.
Any solutions!!
Deploy status
• Querying the active System Definition file from the targets...
• Stopping TCP loops.
Waiting for TCP loops to shut down...
• TCP loops shut down successfully.
• Unloading System Definition file...
• Connection with target Controller has been lost.
• Start Date: 10/5/2016 9:16 AM
• Loading System Definition file: C:\Projects\AP3_VS_2013\STSI_AP3\STS-I-AP3.nivssdf
• Preparing to deploy the System Definition to the targets...
• Compiling the System Definition file...
• Initializing TCP subsystem...
• Starting TCP Loops...
• Connection established with target Controller.
• Sending reset command to all targets...
• Preparing to deploy files to the targets...
• Starting download for target Controller...
• Opening FTP session to IP 192.168.100.242...
• Processing Action on Deploy VIs...
• Setting target scan rate to 4000 (uSec)... Done.
• Deploying XNET database: 253_EVA1_FUELCELL_CAN_2015_29a
• Deploying XNET database: ABC170XNET
• Deploying XNET database: LAB_IMD_CAN
• Deploying XNET database: CVMPro_SingleVoltages
• Deploying XNET database: CFCP_CAN_HUMS_Matrix_RCP_V13_2_150813_Port0_GMCT_noRCP
• Gathering target dependency files...
• Downloading STS-I-AP3.nivssdf [3521 kB] (file 1 of 4)
• Downloading STS-I-AP3_Controller.nivsdat [8249 kB] (file 2 of 4)
• Downloading CalibrationData.nivscal [0 kB] (file 3 of 4)
• Downloading STS-I-AP3_Controller.nivsparam [0 kB] (file 4 of 4)
• Closing FTP session...
• Files successfully deployed to the targets.
• Starting deployment group 1...
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error -307743 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
NI VeriStand: The VeriStand Engine failed to start. A configured start trigger or external timing source did not occur within the specified timeout.
NI VeriStand: NI VeriStand Engine.lvlib:VeriStand Engine Wrapper (RT).vi >> NI VeriStand Engine.lvlib:VeriStand Engine.vi >> NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi >> HP Loop.lvlib:HP Loop Main.vi
10-05-2016 09:56 AM
issue is resolved. reuploaded the FPGA bitfile.
