04-27-2016 02:57 AM
I am using action on download to put some files on RT Target. When I use reference from action on download, every action results in Error -124102. Refrence seems to be valid, when I cast it to I16, the value is 1.
However if I open session manually (with IP and admin username), using open session, everything is working correctly, i am using same paths etc. The reference value of manually opened session is 2.
Has anyone got it working?
VS 2015 sp1
Solved! Go to Solution.
06-06-2016 06:18 AM
Dear thel,
Could you send us some more details about your program? It would be great if I could see the program or see some screenshots.
Sincerelly,
Kornél Nagy
NIEE AE
06-08-2016 12:49 AM
it is solved already, i was using /files/ prefix with relative paths. Without that prefix, all functions works correctly.
09-15-2016 12:32 PM
Error -124102 is also occurred if the path in the target is not exist.
