VeriStand
Error -124102 during action on download
I am using action on download to put some files on RT Target. When I use reference from action on download, every action results in Error -124102. Refrence seems to be valid, when I cast it to I16, the value is 1.
However if I open session manually (with IP and admin username), using open session, everything is working correctly, i am using same paths etc. The reference value of manually opened session is 2.
Has anyone got it working?
VS 2015 sp1
(4,231 Views)
Dear thel,
Could you send us some more details about your program? It would be great if I could see the program or see some screenshots.
Sincerelly,
Kornél Nagy
NIEE AE
Kornél Nagy
RF Systems Engineer
(3,990 Views)
Accepted by topic author thel
it is solved already, i was using /files/ prefix with relative paths. Without that prefix, all functions works correctly.
(3,971 Views)
Error -124102 is also occurred if the path in the target  is not exist.
(3,458 Views)
