05-20-2016 02:49 AM
Hello everyone,
Since a couple of hour, I have some trouble with my VeriStand Project. I have been working on it 2 weeks and since today, on every action that I do on the project I get an error 1172 :
I understand that I have to check this error on MSDN web site but to be honest, when I did it, I didn't understand what I should do ...
After getting this error maybe 5 times, VeriStand crash and gives me this :
I have already try to shutdown my PC but no more success ...
Any idea ?
Thanks !
05-20-2016 03:29 AM
This is a very known error when you are working with NI Veristand .NET API.
Whenever there is a mistake in the code, this error is given, so you can't really tell where is the source of your error.
Do you have a previous working version of your code to realize where the last modification was made and try to solve it?
05-20-2016 03:47 AM
Hum ok thanks for the explication.
Otherwise, this error appears with my other VS project (build without the .NET API) so I am a bit disapointed...
05-20-2016 05:20 AM
Should I uninstall my VeriStand ? Cause nothing is working now ...
05-20-2016 06:29 AM
It's not a VeriStand error, there is no point in reinstalling it.
You need to figure out what is wrong with your code.
05-20-2016 06:49 AM
Ok I have finnaly found the matter. You were right, I have a problem when I had a new port can with the Simple System Definition API.
I must find an other way to add my port.
Thanks again Guilherme !
05-20-2016 07:07 AM
You're welcome.
05-26-2016 03:03 AM
For Guilherme
