02-02-2017 04:49 AM
Hi all,
do you know if is possible compose a UI in NI Veristand UI manager, starting from other UI.
In other words, can I import *.nivsscr files into a root *.nivsscr and obtain a new user inetrface?
The reason of this question is due to a possible certification of my project, for this I would test every subsystem project and to do this in clear mode, decompose the main project in subsystem.
Regards
Solved! Go to Solution.
02-07-2017 07:07 AM
a Veristand UI project can be composed of multiple UI screens! Every screen is then linked to a NI veristand project file.
The files cannot be merged together but you can run multiple of them in parallel.
Regards.
02-09-2017 06:32 AM
Hi ratataplam,
In your Workspace screen, see the screen menu to manage the screen items. With it you can easily add or delete new screens.
I recommend you a veristand formation if you are not familiar with this tool.
