11-03-2014 07:34 AM
I am using VeriStand 2013 SP1. I have all (except CAN bus) of my I/O in an NI-9144 EtherCAT chassis and am using Scan Engine and EtherCAT. The controller is a PXI.
I was trying to find, in DIAdem 2012, the test run where I had a pressure spike that led to the failure of a component.
However, I am unable to search channel properties for "Maximum" as my "Maximum" shows "NOVALUE". I am using a Stimulus Profile for Data Acquisition. All of my channels look like this: Alias, CAN bus (XNET), User Channels, and System Channels.
Can I change anything to remedy this?
Thank you.
11-03-2014 10:29 PM
11-04-2014 08:25 AM
Its called "Update Characteristic Values"
11-04-2014 08:32 AM - edited 11-04-2014 08:33 AM
Stephen,
Since my initial post, I have upgraded to DIAdem 2014, but still see NOVALUE.
When I loaded the file into the Data Portal today, the min/max values were there. However, under Properties for the channel, NOVALUE is still shown so I am still unable to use this as a search criteria (see attached).
Thank you for your assistance.
11-04-2014 08:59 AM
Hey ATarman,
I think you should try asking this question in the DIAdem forum as this is not a NI VeriStand specific issue. Searching around, it appears this behavior happens with any TDMS file. They should be able to help you there.
04-21-2015 01:35 PM
Hey, I am having this exact same issue. Any luck on solving it?
Ellie
04-22-2015 12:29 AM - edited 04-22-2015 12:32 AM
I'm quite sure there is a DIADEM function that allows you replacing NaN values with a specified one. This may solve your problem.
Best regards.
04-22-2015 06:17 PM
As it turns out, I wasn't saving the properties (such as min and max) in the first place.. which is why DIAdem couldn't complete a search for them. If you look at my other post Brad explained it much better. Thanks anyway, though!
Best,
Ellie
