VeriStand
Change pannel sequence
Hi all,
Does it exist the capability to change the screen sequence into VS *.nivsscreen workspace?
I mean :
In traditional workspace (not in UI *.nivsprj file) I can create different screen sections (e.g. screen1,screen2,...)
I can list the result in window dialog box (see below)
    Now I would change the screen sequence in the dialog and swap the position of screen1 and screen2 :
How can I do this ? is there a file to edit I suppose, which?
(2,646 Views)
You can change the order.
.nivsscreen file is written in XML format, you can see the following tag.
<Property Name="Screen Order">
<I32Array>
<Elem>0</Elem>
<Elem>7785</Elem>
</I32Array>
</Property>
Change "Elem" order.
Certified LabVIEW Developer
GCentral
(2,613 Views)
Thanks!!!!
(2,602 Views)
Accepted by topic author zundap1970
Does it work? If it does, please make my answer "solution" : D
GCentral
(2,598 Views)
It works
(2,594 Views)
