VeriStand
CAN_Frames
I managed to run my custom device.
Now I have the problem, that my frames, showed in Channel Data Viewer, don't match to my defined channels.
For example the "Seconds" are shown in "Identifier" and the "hours" shown in "Bit8" (CAN-Message).
What could be the reason?
Custom Device is attached.
Please help.
Thank you!
YesB
(5,721 Views)
Helloo?
(5,703 Views)
Hey YesB,
could you provide a screenshot from VeriStand, how the CAN-Channels are mapped in your application?
I would like to use you custom device in VeriStand, but you don't told us which Version of VeriStand (and which Driver NI-CAN/NI-XNET) do you use. Could you provide this information?
Regards, Stephan
(5,689 Views)
I use following Version:
NI-Veristand 2011 SP1 Version: 11.1.2
NI-CAN 2.7.4
NI-XNET 1.7.0f3
YesB
(5,684 Views)
Accepted by topic author YBilgin
Problem is solved.
The problem was that, I have create section for each added channel.
Just after that you get a right order of created channels for custom device.
YesB
(5,640 Views)
