05-15-2012 07:31 AM
I am trying to do a built of an Simulink Model. I am getting a series of Link errors.
The model is an input port directly connected to an output port.
I am using Matlab 2007b, MS Visual c++ 6.0 and NI Veristand 2011. I am getting following Link errors (attached):
### Linking ...
C:\PROGRA~1\MATLAB\R2007b\sys\perl\win32\bin\perl C:\PROGRA~1\MATLAB\R2007b\rtw\c\tools\mkvc_lnk.pl Test_Mdl.lnk Test_Mdl.obj rt_logging.obj rt_nonfinite.obj NIVeriStand_main.obj rt_sim.obj Test_Mdl.res
link /RELEASE /NODEFAULTLIB /INCREMENTAL:NO /PDB:NONE /RELEASE /NOLOGO -entry:_DllMainCRTStartup@12 -dll kernel32.lib advapi32.lib wsock32.lib C:\VeriStand\2011\ModelInterface\tmw\lib\VC6.0\R2007b\RELEASE\rtwlib_sit.lib @Test_Mdl.lnk /dll -out:Test_Mdl.dll
Creating library Test_Mdl.lib and object Test_Mdl.exp
LINK : error LNK2001: unresolved external symbol __DllMainCRTStartup@12
Test_Mdl.obj : error LNK2001: unresolved external symbol _memset
rt_logging.obj : error LNK2001: unresolved external symbol _memset
NIVeriStand_main.obj : error LNK2001: unresolved external symbol _memset
rt_sim.obj : error LNK2001: unresolved external symbol __fltused
Test_Mdl.obj : error LNK2001: unresolved external symbol __fltused
rt_logging.obj : error LNK2001: unresolved external symbol __fltused
rt_nonfinite.obj : error LNK2001: unresolved external symbol __fltused
NIVeriStand_main.obj : error LNK2001: unresolved external symbol __fltused
Test_Mdl.obj : error LNK2001: unresolved external symbol __ftol
rt_logging.obj : error LNK2001: unresolved external symbol __ftol
Test_Mdl.obj : error LNK2001: unresolved external symbol _memcpy
rt_logging.obj : error LNK2001: unresolved external symbol _memcpy
Test_Mdl.obj : error LNK2001: unresolved external symbol __imp__strncpy
rt_logging.obj : error LNK2001: unresolved external symbol __imp__strncpy
NIVeriStand_main.obj : error LNK2001: unresolved external symbol __imp__strncpy
Test_Mdl.obj : error LNK2001: unresolved external symbol _strlen
rt_logging.obj : error LNK2001: unresolved external symbol _strlen
NIVeriStand_main.obj : error LNK2001: unresolved external symbol _strlen
Test_Mdl.obj : error LNK2001: unresolved external symbol __imp__printf
rt_logging.obj : error LNK2001: unresolved external symbol __imp__printf
Test_Mdl.obj : error LNK2001: unresolved external symbol __imp__free
rt_logging.obj : error LNK2001: unresolved external symbol __imp__free
Test_Mdl.obj : error LNK2001: unresolved external symbol __imp__sprintf
rt_logging.obj : error LNK2001: unresolved external symbol __imp__sprintf
Test_Mdl.obj : error LNK2001: unresolved external symbol __imp__calloc
rt_logging.obj : error LNK2001: unresolved external symbol __imp__calloc
Test_Mdl.obj : error LNK2001: unresolved external symbol _strcmp
rt_logging.obj : error LNK2001: unresolved external symbol _strcmp
Test_Mdl.obj : error LNK2001: unresolved external symbol __imp__atoi
Test_Mdl.obj : error LNK2001: unresolved external symbol __imp__strrchr
Test_Mdl.obj : error LNK2001: unresolved external symbol _strcpy
rt_logging.obj : error LNK2001: unresolved external symbol __imp__malloc
rt_logging.obj : error LNK2001: unresolved external symbol __imp__fprintf
NIVeriStand_main.obj : error LNK2001: unresolved external symbol __imp__fprintf
rt_logging.obj : error LNK2001: unresolved external symbol __imp___iob
NIVeriStand_main.obj : error LNK2001: unresolved external symbol __imp___iob
rt_logging.obj : error LNK2001: unresolved external symbol __imp__floor
rt_logging.obj : error LNK2001: unresolved external symbol __imp__strncat
rt_logging.obj : error LNK2001: unresolved external symbol __imp__strchr
rt_logging.obj : error LNK2001: unresolved external symbol __imp__exit
NIVeriStand_main.obj : error LNK2001: unresolved external symbol __imp__exit
rt_logging.obj : error LNK2001: unresolved external symbol __imp__realloc
rt_logging.obj : error LNK2001: unresolved external symbol __imp__ldexp
rt_logging.obj : error LNK2001: unresolved external symbol __imp__remove
rt_logging.obj : error LNK2001: unresolved external symbol __imp__fclose
rt_logging.obj : error LNK2001: unresolved external symbol __imp__fopen
rt_logging.obj : error LNK2001: unresolved external symbol __imp__fwrite
rt_logging.obj : error LNK2001: unresolved external symbol __imp__fread
rt_logging.obj : error LNK2001: unresolved external symbol __imp__rewind
rt_nonfinite.obj : error LNK2001: unresolved external symbol __imp___isnan
NIVeriStand_main.obj : error LNK2001: unresolved external symbol __imp__tolower
Test_Mdl.dll : fatal error LNK1120: 32 unresolved externals
NMAKE : fatal error U1077: 'link' : return code '0x460'
Stop.
D:\Data\f09561a\My Documents\MATLAB\Test_Mdl_niVeriStand_rtw>echo The make command returned an error of 2
D:\Data\f09561a\My Documents\MATLAB\Test_Mdl_niVeriStand_rtw>An_error_occurred_during_the_call_to_make
'An_error_occurred_during_the_call_to_make' is not recognized as an internal or external command,
operable program or batch file.
### Real-Time Workshop build procedure for model: 'Test_Mdl' aborted due to an error.
Any help in this regard is Appreciated.
Piju
01-03-2013 06:54 AM
I also met this problem,who can solve it?Please tell me,thanks very much!MY EMAIL:534193809@qq.com
04-30-2014 04:56 PM - edited 04-30-2014 04:57 PM
Was this problem ever resolved? I am having the same issues. VS 2011 and Simulink 2012a (32bit). MS Visual Studio 2008 pro. Window 7 64bit.
05-01-2014 12:05 PM
NI came through!! Here is what they said and I got it to work.
Essentially, we call into the MSVC makefile macro to retrieve some of our linker arguments, and the MSVC macro enables the culprit flag (/NODEFAULTLIB).
First of all, let's confirm that you have "Windows SDK for Windows 7 and .NET Framework 3.5 SP1". If you downloaded it from our knowledgebase article, then this version should be correct! Our concern was this was a bug with the SDK but a service pack addressed the issue on MSVC side.
Now, we'll want to backup and modify this macro so that we can modify it. See the steps below:
1) Locate Win32.Mak. Unfortunately, the location this can live in cannot be identified in a straight forward way. You'll want to use Windows Search and search for "Win32.Mak" and repeat steps 2 and 3 until it works. On our system (which has different versions of MSVC and SDK installed), we found it at the following location:
C:\Program Files\Microsoft SDKs\Windows\v6.0A\Include\Win32.Mak
2) Create a backup of this file. DO NOT simply copy and paste this item in a different location because it may fall under the search paths. Instead, append the extension *.bak to the copied file.
3) Open Win32.mak and search for dlllflags . Trace through its definition and confirm that /NODEFAULTLIB is indeed part of its definition. If so, remove it
