Hi, When I use the feature "Apply parameter values from file at initialization",I found it doesn't work as expected . I add two compiled simulink model which called model1 and model2 and creat a .txt file in which I add two parameter form this two models, i changed the initial value of this two parameter and then use "Apply parameter values from file at initialization", after i deploy the system definition file to the target i found only one parameter' initial value form model1 was changed and the other parameter's initial value from model2 was not changed. I don't konw why, could you help me? Thanks!
By the way, the version of my NI Veristand is 2013, and I inported all parameters of the two models when i inported parameters.
