Please post and comments or questions related to the Simulated Thermocouple custom device below
When I try to add this custom device to my system definition I get the attached error.
Thanks for your help.
We are having some problems setting up the channels. It will deploy OK if we do not have any thermocouple channels set up. Once we add channels, we get this error on deployment.
We are using the Scan Engine and Ether Cat Custom device for our analog channels. There seems to be an issue with the ":0" in the channel path.
Any ideas?
Matt
Hi Matt,
Sorry for taking a while to get back to you. It looks like you are somehow trying to add an etherCAT channel under a daq task. The Sim TC code itself doesn't require you to know anything about the TC channel or where it comes from. You should map it to the Custom Device externallly through the mappings.
Are you adding the TC channel to one of the screens in the custom device?
Rossi,
An SMU is not needed. If you read the page on the custom device, the fine resolution and range is achieved by taking any analog out board and setting it up with a voltage divider. Any cDAQ card should be sufficient.
It should also be noted that in order to achieve CJC, you will need a thermocouple module as well. The channel is calibrated witih the CJC of the thermocouple module, and then those values are used in the simulation.
Andrew
