This FPGA personality example allows users to add variable duty cycle and frequency PWM generation and measurement to their NI VeriStand system. This functionality is provided as an example to be used in a bigger, fully integrated system.
To use this FPGA personality as-is:
To customize this FPGA personality for use in your application:
This example was created for use with NI VeriStand. To use this, you must have the following software installed:
1.0.1
This example is provided as open-source software. If it does not meet your exact specification, you are encouraged to modify the example to meet your needs. It is not officially supported by National Instruments.
National Instruments does not support this code or guarantee its quality in any way. THIS EXAMPLE PROGRAM IS PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND AND SUBJECT TO CERTAIN RESTRICTIONS AS MORE SPECIFICALLY SET FORTH IN NI.COM'S TERMS OF USE (http://ni.com/legal/termsofuse/unitedstates/us/).
