NI VeriStand Add-Ons Discussions
Real-Time Sequence Example Library Feedback
Welcome to the Real-Time Sequence Example Library Feedback.  Feel free to leave comments about example sequences that you would like to see.
Nick Keel
Product Manager - NI VeriStand and Model Interface Toolkit
(8,972 Views)
I'm not sure this is the best place to post this question, but I am looking to start/stop datalogging from inside a real-time sequence (which I don't think you can do).
Specifically, I want to change a value in an RT sequence, wait for things to stabilize and then log a very short amount of data (a few samples), then repeat until I have an entire channel sweep of data (just without the transient behavior).  Is there any way to do this?  I would like to avoid heavy post-processing of my data.
Thanks!
Matt Miller
(3,308 Views)
Yeah its possible. When you set up your data log, specify a trigger channel like a user channel or something. Then pass that channel into your RT sequence as a parameter. Then inside your rt seq set that channel value when you want to log samples.
Stephen B
(3,308 Views)
Matt,
For general support questions please create a service request by visiting ni.com/support
You will be directed to post on a dedicated support forum monitored by engineers, or make a phone call, or make an email.
Stephen B
(3,308 Views)
Stephen,
Thanks for the quick response.  That sounds easier than I thought.  That will be very helpful when we get it working.
Matt
(3,308 Views)
