03-22-2013 09:38 AM
Hi John,
I'm sorry for the troubles. Lets see if we can make some progress.
I have a lot of questions:
<Version>2.0.1</Version> |
03-22-2013 10:13 AM
#1 - No output (Infinite Resistance) and no errors
#2 - 2.0.1
#3 - no error codes
#4 - no error information on console
03-22-2013 10:23 AM
Thanks for the info. Can you attach the sysdef? (click use advanced editor i the top right to bring up attachments)
03-22-2013 10:33 AM
attached
03-22-2013 10:49 AM
John,
This sysdef has a lot of things in it. Can you try making a copy and deleting everything except the resistive simulation custom devices and see if that works correctly?
Also, another thing to try would be using just one instance of the resistive simulation custom device, but picking different hardware each deploy. That way we can figure out if its a hardware or software problem.
03-22-2013 10:59 AM
For the cards that aren't working, do you see the actual value channel change when you change the desired value?
03-22-2013 11:23 AM
Created a new project to do that now can't run it
• Loading System Definition file: C:\Users\Public\Documents\National Instruments\NI VeriStand 2011\Projects\Resistance Test\Resistance Test.nivssdf
• Preparing to deploy the System Definition to the targets...
• Compiling the System Definition file...
• Starting VeriStand PC Engines...
• Initializing TCP subsystem...
• Starting TCP Loops...
• Connection established with target Controller.
• Sending reset command to all targets...
• Preparing to deploy files to the targets...
• Starting deployment group 1...
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error -200220 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
Device identifier is invalid.
NI VeriStand: Property Node DAQmx Device (arg 2) in ni272x Error Check Product ID.vi:8->ni272x Initialize Session.vi:2->NI 272x Resistive Simulation Custom Device Engine.lvlib:Engine Initialize.vi:1->NI 272x Resistive Simulation Custom Device Engine.lvlib:Driver.vi:1 <append>
Device Specified: 2725Slot8
• Shutting down VeriStand PC Engines...
• Unloading System Definition file...
• Connection with target Controller has been lost.
03-22-2013 11:25 AM
Yes but when I measure the output from the card I don't get anything
03-22-2013 11:33 AM
The VeriStand Gateway encountered an error while deploying the System Definition file.Details:
Error -200220 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.viPossible reason(s):
Device Specified: 2725Slot8* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * *
03-22-2013 11:43 AM
DAQmx is 9.6.0
