08-26-2014 06:20 PM
Actually a better work around for #1 is to toggle 'reverse data' on and off
08-26-2014 06:43 PM
Well it's moot anyway, easy fix. 1.2.2 is up now with a fix.
08-27-2014 08:58 AM
Looks good, thanks!
09-18-2014 01:54 PM
Hi Stephen,
I found that Engine simulation toolkit cannot work with NI-XNET. I have tested NI-XNET and engine simulation toolkit separately and they worked well. But as long as NI-XNET and engine simulation toolkit get configured in the same Veristand project, I will receive the following error message:
Details:
Error -61200 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
LabVIEW FPGA: The operation could not be performed because the FPGA is busy operating in FPGA Interface C API mode. Stop all activities on the FPGA before requesting this operation.
I have a customized bitfile specified in engine simulation toolkit. But it worked fine with other functionalities such as Scan Engine and Ethercat and Simulation Model etc.. By specifying a bitfile in the toolkit, I believe the FPGA will be executing the bitfile during operation. Will this be a problem if I want to use CAN communication?
(I have a cRIO-9082 with 3 NI 9862, 1 NI 9205 and 3 NI 9401 )
Thanks.
Jian
09-18-2014 09:42 PM
Hi Jian,
Sorry to hear you're having issues. Hopefully we can get this resolved. Using XNET in the same bitfile as the Engine Simulation Toolkit should work no problem.
I normally see that error when two different bitfiles are attempted to be loaded to the same FPGA target. Are you sure you're selecting the exact same bitfile from both the XNET portion of System Explorer and the Engine Simulation Toolkit?
Can you open the web console of your target and copy and paste the error from there? It should have more information. Visit your target by typing its IP address in your web browser. Then select the console button on the left side.
Take care
09-22-2014 11:50 AM
Thanks a lot, Stephen.
The cause is that I used two different bitfiles. Now CAN is working with engine simulation toolkit.
Jian
09-22-2014 12:15 PM
Great!
09-24-2014 03:22 PM
I'm getting an error using this toolkit in VeriStand:
Here are are the steps to reproduce the error:
1. Create a new VeriStand project and open the system definition.
2. Add the "Engine Simulation Toolkit" custom device.
3. Browse to the shipping bit file "EngineSimulation_FPGATarget_Everything_-maPPEweIOY.lvbitx".
4. Select Digital Patterns and click the "+" button twice to add two digital patterns (the error doesn't happen if you just add 1 pattern).
5. Select any other item in the system definition tree.
6. Now select the "Digital Patterns" item agian and I get error 1055 shown below.
Note: I'm using VS 2013
09-24-2014 04:09 PM
Hey Todd,
I just reproduced that. Thanks for the steps. Looking into it now
09-24-2014 04:21 PM
I have a fix in, it is building now and should be up online soon.
