NI VeriStand Add-Ons Discussions
Chassis TimeSync Custom Device Feedback
This is what I get now. Attached is the screenshot.
Message 31 of 115
(4,696 Views)
Can you please check the format of entering the module name and sync method, if I have the correct name in there? Attached is the screenshot.
Thank you
Message 32 of 115
(4,696 Views)
OK thanks for your patience. I have been busy this morning so I'm just getting to this.
Error code 7 means the file was not found on the target. Can you FTP in and navigate to that path and see if the file is actually there?
The setup you have for the device name is fine as long as the 6683H is named that in MAX. by default its named something like PXI1Slot7 so you will need to either rename it in MAX or in your custom device.
Stephen B
Message 33 of 115
(4,696 Views)
I keep running into this error:
Details:
Error -307673 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
NI VeriStand:  Another VeriStand Gateway already is connected to the execution host. Only one VeriStand Gateway can be connected to an execution host at a time.
NI VeriStand:  NI VeriStand Gateway.lvlib:VeriStand Server Wrapper.vi >> NI VeriStand Server.lvlib:NI VeriStand Server.vi
<append>=========================
NI VeriStand:  The target Controller is already connected to the VeriStand Gateway running on host 192.168.100.27.
Message 34 of 115
(4,696 Views)
Could you confirm that you have both the f1 and f2 patches installed? In the f2 patch for 2012 we fixed an issue where this error appeared as a result of multiple network connections on a single computer connecting to a target configured with a static IP address.
Senior Systems Engineer
Message 35 of 115
(4,696 Views)
I was about to say that! thanks Lynn. f2 is inclusive by the way so you can just install that.
Stephen B
Message 36 of 115
(4,696 Views)
Yes I installed that now, I was missing the f2 patch. Now I get this error message
Details:
Error -200077 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
NI VeriStand:  Property Node DAQmx Timing (arg 1) in DAQ Engine.lvlib:Set task reference clock.vi->DAQ Waveform Engine.lvlib:Set Task Timing.vi->DAQ Waveform Engine.lvlib:Initialize DAQ Waveform Data.vi->NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi->NI VeriStand Engine.lvlib:VeriStand Engine.vi->NI VeriStand Engine.lvlib:VeriStand Engine Wrapper (RT).vi <append>
Property: RefClk.Rate
Requested Value:  100.0e6
You Can Select:  10.0e6
Task Name: Trigger
Message 37 of 115
(4,696 Views)
I dont see that task or any DAQ devices in the system definition you posted earlier. Can you post your new one?
Stephen B
Message 38 of 115
(4,696 Views)
Also, after installing the f2 patch on your host computer, did you reinstall NI VeriStand to the target? (so it gets updated to f2)
Stephen B
Message 39 of 115
(4,696 Views)
Message 40 of 115
(4,696 Views)
