NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
fasttech
where is modelsupport.dll
Active Participant
aperez
Re: where is modelsupport.dll
It should be in the following folder:
\Components\NI\Models\TestStandModel
Azucena Perez
Member
fasttech
The modelsupport2.dll is in the TestStandModel directory, but not modelsupport.dll. The functions I need were in the original modelsupport.dll file packaged with TestStand 1.0.2. The functions needed are UIMessage_Event calls.
Trusted Enthusiast
RayFarmer
If you are using TestStand 2.0 then you need to use modelsupport2.dll. The UIMessage functions are still there.
If you are using the User folders, then you will have to copy the new NI folders across to the User folders. Making sure you have backed up first.
Ray.
Regards
Ray Farmer
Member
fasttech
I have looked in this dll, and I don't see the function we use called PostUIMessage.
Trusted Enthusiast
RayFarmer
NI have removed a load of wrapper functions from the modelsupport.dll. The API function PostUIMessage is still available (Thread.PostUIMessage) so it looks like you will have to use the API function or the new PostUIMessageEx function.
Regards
Ray.
Regards
Ray Farmer
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
