watch expression in Operator Interface (Teststand3.1)
For debugging purpose, I want to integrate a watch expression in the teststand operator interface like in the sequence editor.
My first attempt was to insert a UIControl in the operator interface and use a Connect-Method to connect it with the WatchExpressions-collection. But I didn't find an appropriate UIControl or an Connect-Method.
Now, my second attempt is to wait for one of the following events (not sure which to use, seem's there is no WatchExpression-Event):
-ExecutionViewManager.Trace-Event
-ExecutionViewManager.ContextChanged-Event
-ApplicationManager.RefreshWindows-Event
With the event I get the SequenceContext of the current displayed Execution and I can evaluate the watch expressions and update a value-display (using the PropertyObject.GetFormatedValue-Method). To build the watch expression, I can use the ExpressionEdit-UIControl or an simple text control and store it in the WatchExpressions-Collection or a array of string.
Does anyone know a easier way to implement watch expressions in operator interface?!
(3,736 Views)
LVFan -
That is basically the way that the TestStand sequence editor does it. You must wait until a valid context is available to reevaluate the expressions.
Scott Richardson
(3,719 Views)
There was a tools created in CVI that you could add to you tools menu that provided a watch window. I have used it with the LabVIEW OI, but it does require that you have installed on your target machine the developement teststand environment.
It worked with Teststand 2.01f1. It was on the NI website but as yet I haven't been able to find it.
I might still have a copy of it.
Regards
Ray Farmer
Regards
Ray Farmer
(3,709 Views)
Hello Ray Farmer,
can you tell me,  if the tool (Watch window for OI) somewhere in NI-Web is avaible.
(3,488 Views)
I can not find it on the website, so its probably been removed.
I'll see if I still have a copy of it for you.
maybe this link maybe of help to you
http://digital.ni.com/public.nsf/websearch/4F8AEC68AE27C99386256BB8006DD3D4?opendocument&Submitted&&...
Regards
Ray Farmer
Regards
Ray Farmer
(3,480 Views)
Found a copy. see attached
regards
Ray Farmer
Regards
Ray Farmer
(3,464 Views)
