This widget could not be displayed.
NI TestStand
tooltip
Hello
I'm working on the translation in french of the UI. I have problem with tooltip.
In the picture below, you can see that the settings of steps are translated in french. The tooltip is still is english. I've searched the ini configuration files but didn't find the "Sequence Call Tracing: Disable" string. So where are defined tooltips ?
Anybody has an idea to solve this problem ?
Laurent
(2,896 Views)
I can't see your picture, but a lot of the strings have replacement macros in them so searching for the string exactly will probably not work. For example, the string might really be "Sequence Call Tracing: %1" in the ini file. I recommend searching for just "Sequence Call Tracing" and "Disable" separately.
-Doug
(2,870 Views)
