NI TestStand
teststand Custom steps
Hi All,
I am working on  couple of projects A & B, which has custom steps specific to the projects.
If i want to work on Project A i need to remove all custom steps related to Project B and add all INI files related to Project A.
Do we have any other option where we can store custom steps infomation ?
Best Regards
Manasa M
(3,067 Views)
Manasa,
you can store the step types in the sequence files of each project. While this is most likely not the best solution, it could be a working one.
You could also create a tool which automizes the removal/adding of custom INI which is used for loading A or B.
As last option, you could change the TestStand Configuration Directory to project specific folders.
Norbert
Norbert
Expert: Geometry
(3,063 Views)
Hi Manasa,
You can create a type palette file to store your Custom Step Types in, rather than the sequence file itself.
Regards
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(3,061 Views)
