Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
04-03-2017 02:36 AM
在teststandII中lesson1 中: 如何利用activeX/COM 动态地插入一个局部变量?
Develop a small sequence that programmatically insert a local variable using the Active X/COM adapter.
04-03-2017 05:27 AM
The steps needed to dynamically add a variable are covered by this KnowledgeBase article:
How Can I Programmatically Create Variables in TestStand?
Just change the lookupString to the local name you require, eg. "Locals.NewVariable"
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
Thanks!
We'll be in touch soon!
