02-28-2007 11:23 AM
03-07-2007 11:14 AM
03-08-2007 01:44 AM
Hello Amir,
Thank you for your help
It works with storing a waveform into report. Now I want to store a upper and lower limit waveform (envelope) into the same graphic in the report. That makes problems.
I thought that I can do it by replacing the variables step.limits.low and step.limits.high with array of numbers with the same name, but that does not work.
The second thing I tried is to create a 2D array step.Result.Measurement[2][number of samples] ( step.Result.Measurement[lowerlimit][number of samples], step.Result.Measurement[measurement][number of samples], step.Result.Measurement[upperlimit][number of samples]).
But when I want to read the report I says "Unable to process the XML Report with stylesheet 'C:\Programme\NationalInstruments\......\horizontal.xsl
I think that the horizontal.xsl does not support displaying a 2D array
Do you have an Idea to solve that problem?
Regards samuel
03-27-2007 10:31 AM
Unfortunately, I did not found horizontal.xsl file. Could you please posted for me the path? Thanks. Please tray to a little bit more describe what is your goal?
AmirG
04-12-2007 01:53 AM
Hello AmirG,
The path for the horiziontal.xsl is: .....\TestStand 3.1\Components\NI\Models\TestStandModels\StyleSheets\horizontal.xsl
I want to measure a waveform with a DAQ interface and then I want to compare it to a upper and lower limit waveform (envelope). If one sample is outside of the envelopes then the test is failed. And I want to visualize the measured waveform with upper and lower limuts waveform in the same graphic into the report
thank You
regrads samuel
