06-08-2006 08:08 AM
I ended up going with the combo box. Thanks. I have another related question. In that same dialog, I have a string file path control. In the sequence editor's View Station globals, I don't know what type this equates to. I tried 'string' but that didn't work.
In general, is there a table that shows the conversion between TestStand types and LabVIEW types.
06-08-2006 08:56 AM
06-08-2006 09:16 AM
06-08-2006 09:31 AM
06-08-2006 10:20 AM
In the Select Type (right-click option of the Test Stand Get Property Value.vi) I had selected String Array in one of my experimentations. I changed this to String and it worked.
I'm still struggling, however, to know how the various TestStand types map to LabVIEW types. Is there a table somewhere? TestStand's Object Reference, Container, Types::Path are not clear to me.
06-08-2006 10:29 AM
06-13-2006 01:09 PM
I was able to read in all the strings from my StationGlobals.ini file and populate the dialog box with them. However, when I try to read the CalibrationData, I receive an error inside the TestStand Get Property Value call. I've tried setting the StationGlobals type to string and to path, with the LV conversion from string to path inbetween the property node. Anything glaring that I'm doing wrong?
06-13-2006 01:12 PM
You probably need to have the path string using \\ (two backslashes) in your TestStand Variables.
Regards
Ray Farmer
06-13-2006 01:28 PM - edited 06-13-2006 01:28 PM
You String for "StationGlobals.ATEReg.CalibrationData" has an extra space on the end of it eg "StationGlobals.ATEReg.CalibrationData "
and also the LogFile lookupstring.
and also the StationData lookupstring
Regards
Ray Farmer
Message Edited by Ray Farmer on 06-13-2006 07:30 PM
Message Edited by Ray Farmer on 06-13-2006 07:31 PM
06-13-2006 02:53 PM
Ray,
I cannot find this extra space. I think it just may be an optical illusion due to loss of quality in converting to a bitmap. I've looked in the View::StationGlobals and in the .ini file. Is there somewhere else I'm missing? Also, my string in the .ini file does have the double backslash (i.e. "C:\\ATE\\StationInfo\\CalData.txt")
I've attached a file showing the error message I receive.
