06-07-2006 07:48 AM
06-07-2006 11:00 AM
The answer to part 1
Yes. Hightlight the item to change, then select Replace Global, then you can select what to replace it with. If the item was in a Container, then It will say Replace Field.
Hope this helps
Regards
Ray Farmer
06-07-2006 11:11 AM
06-07-2006 11:18 AM
I forgot to say, if you are passing a Constant, then you can select the Enum from the the drop down control in the Specify module Dialog.
Regards
Ray Farmer
06-07-2006 11:54 AM
06-07-2006 01:35 PM
06-07-2006 02:32 PM - edited 06-07-2006 02:32 PM
The "value" of an enum is not a string! The default data type of an enum is a U16 number. Just look at the terminal on the block diagram. Strings terminals are red and numeric terminals are blue. You would have to use the Strings[] property of an enum to do what you want. The easiest thing for you do is to use a combo box. The value of a combo box is a string. You might want to look into taking some LabVIEW classes. Information on those and on-line tutorials can be found at http://www.ni.com/devzone/lvzone/fundamentals.htm .
Message Edited by Dennis Knutson on 06-07-2006 01:33 PM
06-07-2006 03:14 PM
Your not having much success because it sounds like you are looking in the actual ini file. You need to be doing the action I discribed from the SeqEditor.
Regards
Ray Farmer
06-07-2006 03:23 PM
06-07-2006 03:32 PM - edited 06-07-2006 03:32 PM
Ok,
Select a variable and then click left mouse button. you should see the Replace selection.
see attachec PNG's.
Regards
Ray Farmer
Message Edited by Ray Farmer on 06-07-2006 09:34 PM
