NI TestStand
sequence context
Hi all ,
Is there any difference in execution time from passing a value using wires in Labview (v/s) calling the sequence context and then calling set property ?
kindly let me know .
(3,548 Views)
Accepted by topic author Padugur
Hello Padugur,
please look into this thread:
Sequence Context vs. Parameters
Normally wire are and parameters are faster then setting a value thru a property node.
best regards
Alexander
(3,504 Views)
Its always better to go by passing the output results directly to variables than using sequence context.
(3,494 Views)
