07-28-2013 09:34 PM
Hi Guru,
How to send a value into 2 different variables as i attach in the attachment.
Solved! Go to Solution.
07-29-2013 12:34 AM
07-29-2013 01:44 AM
hi J_dodek,
other than use the PostEkspression method, is there any other way?
08-01-2013 06:07 PM - edited 08-01-2013 06:08 PM
You can write to these variables in your LabVIEW code. Pass a refernce from your sequence file to your LabVIEW code and then use the TestStand pallete in LabVIEW to write to both variables.
Shane.
