07-09-2013 04:16 AM
hi,
my org. needs the report to be saved in TDM format (standard format in our Org.)
we have recently implemented teststand
is there a TDM plugin available for teststand which i can use in Result processing (teststand)
or has anybody other workaround for the same
07-09-2013 04:24 AM
TDM is a file format for measurement values, so not necessarily meant to store execution results of a TestStand sequence execution.
So in short:
No, there is no plugin or whatsoever to create a TDM file storing results of a TestStand test.
You can implement your own plugin for this, but it will be a bunch of work and i question the content of that TDM file.
If you want to store measurement values in TDM (raw data used by TS to determine the result of the DUT), you should use the module to save those values in TDM(S).
hope this helps,
Norbert
07-09-2013 05:19 AM
Are you already using TestStand?
Do you report your results as ATML(5)?
In this case you can use the ATML DataPlugin to read the ATML data and convert it to TDM (using LabVIEW or DIAdem).
07-10-2013 01:31 AM
thanku all for the response
03-10-2014 03:42 AM
well there are a lot of issues with the ATML plugin from NI
and secondly we want to use the TDM so that the report structure could be customized
has any one tried that
