07-15-2005 06:41 AM
07-15-2005 11:55 AM
Hi Nicole,
I assume that you want to get the behavior you get when you configure the sequence call step to run the subsequence within the same thread. (MultiThreading and Remote Execution = None).
You do not get the result list array of the subsequence because you are running the sequences in a new execution and every execution keeps its own copy of the local variables.
You could use a station global variable to save your result list every time you execute the sequence in order to have access to these results in the other executions.
If you synchronize your steps properly you can make sure the results contained in the station variable correspond to the last sequence execution.
Take a look to the attached example.
Hope it helps.
07-19-2005 03:53 AM
