12-14-2010 06:27 AM
The LabVIEW DLL which I have created are not loading the prototypes in TestStand.
I have selected C/C++ Dll as the Adapter type in TestStand. It is showing following popup
"This function either does not have parameter information in the DLL or uses types not recognized by TestStand".
I found out that this issue is because of the Error Cluster as the parameter in DLL.
Can anyone tell me how can I solve this issue caused by cluster as parameter in the DLL?
Thanks in Advance...
08-07-2013 07:59 AM
Maverick,
I'm having the same problem. This may help you:
http://digital.ni.com/public.nsf/allkb/22BF02003B4588808625717F003ECD67
What versions of LabVIEW and TestStand are you using?
