07-06-2015 02:51 PM
According to link below, TS support some regular expression. Can anyone provide an example of where to write the regular expressions ?
I might be easier to do it via an external .net module, but if TS supports it, i might go with that.
http://zone.ni.com/reference/en-XX/help/370052N-01/tsref/infotopics/find_regular_expressions/
Solved! Go to Solution.
07-06-2015 06:36 PM
If you are using a PropertyObject Search method there is a parameter called SearchOptions. It requires one of the SearchOptions Constants. One of those is called SearchOptions_RegExpr. When this is passed for that parameter then the search text can contain regular expression characters. This is of course 1 example.
What specifically are you wanting. Maybe there is an easier way?
Hope this helps,
07-07-2015 03:22 AM
I wish to take this string:
{x=8.28504, y=0.10767,z=-0.26559}
And get x,y,z values in seperate varibles.
can be done in C# with this regex:
{x=(?<x>-?\d\.\d{5})\,y=(?<y>-?(-|)\d\.\d{5})\,z=(?<z>-?(-|)\d\.\d{5})}
I have made a piece of code for that, however it would be nice to do it directly in TS.
07-07-2015 06:39 AM - edited 07-07-2015 06:41 AM
HI
Yes there is a PropertyObject.Search Member but the result is from SearchResults so i wonder how to use this in executing sequence ?!
What about a simple workaround by using just 4 lines in Exression statement to achive this by using split and trim ?
Regards
Juergen
07-07-2015 11:13 AM - edited 07-07-2015 11:14 AM
You can also use an Action step with the .NET adapter to directly call the .NET framework regular expression APIs to do this.
Hope this helps,
-Doug
07-17-2015 04:23 AM
Thanks for the support.
I've not yet tried your suggestion Doug, but i intend to.
