07-21-2006 10:27 AM
07-21-2006 11:30 AM
The expected way to do that is to not ignore the error and to put the steps that must run whether or not an error occurs in your cleanup step group. If you have cleanup steps that should only execute when an error occurs, you can give them a precondition of:
RunState.SequenceError.Occurred
Another method of customizing error handling is to define a SequenceFilePostStepRuntimeError callback sequence in your sequence file, or a ProcessModelPostStepRuntimeError callback sequence in your process model. There is an example in:
TestStand\Examples\Callbacks\PostStepRuntimeErrorCallback\
