NI TestStand
property loader load from database issue
Hi All,
I am fighting hard with Property loader.
As u can see in the seq. file ,  I have to name the "Numeric limit Test" same as the row in the database or "Numeric limit Test" should exist in the database Table.
Is there a workaround for this!
database table
SAP_MaterialID                LIMITS_LOW                  LIMITS_HIGH                     Tout
101 66 666 50
102 7334 8567 3
103 6 897 49
104 5 7 52
105 33 83 53
NULL NULL NULL NULL
(3,905 Views)
HI
Sorry, I don´t understand what you mean.  What do you want exactly. Do you want to dynamically name the step during execution?
So what I mean is, first column first row in the first iteration set the name of the step to 101. Second iteration 102.
best regards
(3,864 Views)
Hi BRennhofer,
thanks for ur response!
No I dont want  to rename the steps but unfortunately the Property Loader  demands  that the  step Name be part of the database table
and that is the issue.
I am trying for a solution or a workaround for this.
regards
(3,860 Views)
I'm not sure but please try to uncheck this:
(3,851 Views)
forgot the pictures
(3,848 Views)
The property loader step type expects a column to be named STEPNAME and the name of the value in the database must correspond to a step name in the sequence that you will be import properties into. One option is to customize the name that is returned from the SQL recordset:
"Select SAP_MaterialID as STEPNAME, Limits_high, Limits_Low from LIMITS"
Scott Richardson
(3,779 Views)
thanks Scott,
i think the property loader expects   the SAP_MaterialID  values 102, 103 ... as the step name  & then it works ok
(3,774 Views)
