06-28-2013 02:19 AM
Hi All,
I am fighting hard with Property loader.
As u can see in the seq. file , I have to name the "Numeric limit Test" same as the row in the database or "Numeric limit Test" should exist in the database Table.
Is there a workaround for this!
database table
SAP_MaterialID LIMITS_LOW LIMITS_HIGH Tout
101 | 66 | 666 | 50 | |
102 | 7334 | 8567 | 3 | |
103 | 6 | 897 | 49 | |
104 | 5 | 7 | 52 | |
105 | 33 | 83 | 53 | |
NULL | NULL | NULL | NULL |
07-01-2013 07:50 AM
HI
Sorry, I don´t understand what you mean. What do you want exactly. Do you want to dynamically name the step during execution?
So what I mean is, first column first row in the first iteration set the name of the step to 101. Second iteration 102.
best regards
07-01-2013 08:27 AM
Hi BRennhofer,
thanks for ur response!
No I dont want to rename the steps but unfortunately the Property Loader demands that the step Name be part of the database table
and that is the issue.
I am trying for a solution or a workaround for this.
regards
07-01-2013 09:56 AM
I'm not sure but please try to uncheck this:
07-01-2013 09:58 AM
forgot the pictures
07-15-2013 01:16 AM
The property loader step type expects a column to be named STEPNAME and the name of the value in the database must correspond to a step name in the sequence that you will be import properties into. One option is to customize the name that is returned from the SQL recordset:
"Select SAP_MaterialID as STEPNAME, Limits_high, Limits_Low from LIMITS"
07-15-2013 02:11 AM
thanks Scott,
i think the property loader expects the SAP_MaterialID values 102, 103 ... as the step name & then it works ok
