12-06-2005 10:17 AM
12-06-2005 10:53 AM
If there are sequence calls that you know are not required to logged to the results. Then disabling in the properties of the that step will also mean you will not get the results for the sub-sequence steps.
Alernatively, you can set the disable property in the Sequence Properties Dialog for any Sequence that you dont want to log results.
Otherwise, you are down to going through your sequencefile and sequences to disable the the logging that are not required.
You could generate a sequencefile to do that work, by loading each Sequencefile and working through each step. But you will have to apply some sort of rules, such as disable all steps in Setup and Cleanup groups or only enable Test type steps such as PassFail etc.
Hope is helps
Ray Farmer
12-07-2005 01:43 AM
12-07-2005 07:37 AM
I'll try and get you an example later today as I dont have access to TestStand at the moment.
One other possibility would be to modify the report generation sequence file. to check if the type was one of the required types and skip on all the others.
Regards
Ray Farmer
12-07-2005 04:22 PM
Attached is a small example.
At the moment it will only do one sequencefile at a time and only looks at the steps in the Main of the sequence "MainSequence".
It will obtain a list of steps in the Main of MainSequence of a Selected SequenceFile. It will then loop on all the selected steps. if the step is an Action step, it will switch of the Result Setting.
Give it a try.
Regards
Ray Farmer
12-08-2005 08:23 AM
