NI Home
Cart Cart | Help
You are here:
Reply
Member
AlexTestStand
popup message response
Hello.
In popup response, I would like to have the possibility to write in multiple line.
but if I pressed the enter button on the keyboard, this active the ok button of the popup.
Is that possible to change the line in the response or not (to do a kind of check list) ?
I need to write something like follow in the response on the message popup:
"comment 1
comment 2
And I also need to see it in my report, if I have just one line, it is ok, I can see it in my TestStand report.
But if I write multiple lines, could I see it always in the report.
Alex
Trusted Enthusiast
Norbert_B
Re: popup message response
Have you tried Ctrl+Enter?
If you really want to have Enter alone as new line command, you can select "None" as default button in the button options settings (instead of Button 1).
Norbert
Member
AlexTestStand
oh damm !!
how I do to not fint it by myself...
but it concatenates the lines in 1 line in the report.
Is there a solution to have multiple lines in the report ?
Alex
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
