NI TestStand
passing reference to .net assembly
I have the following problem:  I am trying to write an  C# application that is able to set the values of all  local Variables in a Teststand sequence. So I tryed to pass the "Locals" reference  to my assembly but it doesn't work. I don't know if somebody can help me..
regards,
andré
Teststand 3.5
Visual Studio 2005
(2,866 Views)
It is very simple, you must to use the API of your #C DLL/EXE
1. Create step
2. Specify adapter that suits for #C
3. Choose your DLL
4. Use API of your method/function to get desirable Locals...
Good luck Smiley Wink
Thank you & Best Regards
*I use LabVIEW 2018 & TestStand 2021 versions
(2,857 Views)
thanks yuri for ur answer,
i already found the solution..
regards,
andré
Teststand 3.5
Visual Studio 2005
(2,842 Views)
