02-24-2007 06:13 PM
02-25-2007 08:04 PM
Make Call SubSequence
Use the button value of the pressed button 0,1,2 so on
Use post expression form the TS Expression to solve your if conditions for Pass Fail and also check the Go on Pass and Go on Fail
Keep your Main Sequence easy to read(mininual program flow control) only the sub sequence calls
MainSequence
SubSequence1 Operator Input validationI(parameter.output of button press) if parameter.outputofbutton pressed=2 Goto Clean up (example). The labview code return the value to the teststand module.
SubSequence2 Test One
Hope it help a little(myTwoCents)
Good luck. You Can Do It.
02-26-2007 07:52 AM
02-26-2007 08:04 AM
